Force Affector
Force Affector
Applies a force to particles.
This node applies a force to the affected particles. This is typically used to give particles a constant acceleration to simulate e.g. gravity.
Amount How strong an effect the force has on the particles.
Mode Change which kind of force is applied.
  • Directional Force : The force is applied directionally along the Z+ axis.
  • Repel : The particles move away from the node.
  • Attract : The particles move towards the node.
  • Node Motion : Use the direction and speed of the Force Affector node’s own motion as the force vector.
Transform NodeApply the transforms of other nodes to this node.Null
Force TransformerTransforms the force direction.Null
Parameter Value ArrayUsed to set the parameters of the node using a float array.Parameter Array
