Emissive Material
Add an emissive material.
This node generates a basic emissive material, similar to the default material node but without any specular settings.
| Preview in Viewport | Toggle a preview of the Material on a sphere in the Viewport. |
| Colour | The colour of the material. |
| Brightness | The brightness of the material. |
| Normal Map Mode |
| Emissiveness | How much of a glow is emitted around the object. |
| Emissive Scattering | Controls how much Emissive lighting is scattered in the scene. |
| Emissive Lights Scene | Controls how much Emissive lighting contributes to lighting the scene. |
| Use Displacement | Enables the use of displacement mapping for the material. *Requires an input displacement map. |
| Diffuse Lightmap | Enables an input diffuse lightmap for the material. |
| Diffuse Map | Specifies the color of light that scatters off the surface in all directions. It is functionally similar to the Colour Texture and is a core component of a material’s appearance. |
| Emissiveness Map | Determines which parts of a material appear to glow or emit their own light. Brighter values cause the surface to act as a light source. |
| UV Texture Filter Mode |
| Diffuse Map -> AO |
A setting to use the Diffuse or Colour map to contribute to the Ambient Occlusion calculation, often darkening areas based on the base color.
| Diffuse Map UV | Select the UV for the Diffuse Map Texture. |
| Emissiveness Map UV | Select the UV for the Emissiveness Map Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Lit |
Determines if the material is affected by lights in the scene. When disabled, the material appears fully lit by its own colour and texture, regardless of scene lighting.
| Shadows |
| Raytracing Settings |
| Polygon Sidedness |
| Vertex Colours - Apply To Emissiveness | Set how the vertex colours apply to the emissiveness of the mesh. |
| Normal Map Intensity | TODO |
| Invert Normals | Flip the normals of each face, so the lighting is tested against the inside face. |
| Displacement Offset | Adds an initial offset to the displacement. |
| Displacement - Use Polygon UVs | TODO |
| Subsurface Weight | Weight of the subsurface scattering effect. |
| Subsurface Scatter Radius | Radius of the subsurface scattering effect. |
| Baked Diffuse Intensity | TODO |
| Rim Lighting Use Material Colour | TODO |
| Rim Lighting Colour | TODO |
| Rim Lighting Intensity | TODO |
| Rim Lighting Falloff | TODO |
| Resolution Limits |
TODO
| Max Width |
TODO
| Max Height |
TODO
This node has no inputs.
| Colour Texture | A texture to apply to the object that defines its colour. | Video Loader |
| Diffuse Texture | Texture applied spatially to object that defines its diffuse map. | Video Loader |
| Specular Map | Texture applied spatially to the object that defines its specular. | Video Loader |
| Emissiveness Map | Texture applied spatially the object that defines its emissiveness. | Video Loader |
| Metallicness Map | Greysacle texture applied spatially to the object that defines its metallicness. | Video Loader |
| Roughness Map | Greyscale texture applied spatially to the object that defines its roughness. | Video Loader |
| Normal Map | Texture applied spatially to the object that defines its normals. | Generate Normal Map |
| Displacement Map | Texture applied spatially to the object that displaces the vertices of the model’s geometry. | Video Loader |
| Alpha Map | Texture applied spatially to the object that defines its transparency. | Video Loader |
| Ambient Occlusion Map | Texture applied spatially to the object that defines its ambient occlusion. | Video Loader |
| Subsurface Colour Map | Texture applied spatially to the object that defines its subsurface colour. | Video Loader |
| Subsurface Weight Map | Texture that controls the intensity of the subsurface scattering effect. | Video Loader |
| Composite Nodes | Use shader nodes to override the compositing stage of the shader pipeline. | Channel Sampler |
| Mapping | Control how the image input is mapped onto the mesh for displacement. | Mapping |
