Curl Noise Warp
Warps using a curl noise function.
This node warps and image using a curl noise function.
| Displacement Amount | How much the warp effect displaces the image. |
| Noise Scale | Size of the noise in the warp. |
| Falloff Range | How far the falloff for the warp reaches. |
| Simulation Speed | Control the speed at which the warp is animated. |
| Edge Fade Distance | How much of the edge is effected by the warp from the center. |
| Update Time Mode |
How the effect updates with relation to the time code.
| Falloff Node | Add a gradient that controls how far the effect affects the image. | Gradient 2D |
| Effect Amount Image | Input to control the amount of the effect based on the colour data of an image. | Gradient |
| Mask Image | Add an image which controls areas which are not affected by the warp effect, using the images luminance. | Image Plane |
