Gradient 2D Renderer
This node generates a 2D Gradient based on the positions and colours of active particles.
Alpha How much the rendered gradient blends with the scene.
Blend Mode How the gradient blends with the scene. See Blend Modes for details.
Falloff Scale Scale the size of the falloff.
Falloff Power How strong the falloff is.
