Procedural
Use a Procedural in a shading system.
This node uses a Procedural System as a shading value source, converting the distance field from the procedural for use in the shading system.
The output of this node is a shader, which can either be combined with other Shading nodes for a more complex design, or applied to Materials to directly control one of the material channels. They can also be applied to Fields, where they can be used on the various channels on the Field Emitters to control how the smoke is generated, and Field Materials to control how the field is rendered.
| Preview In Viewport | Preview the effects of the shading node on the channel it’s applied, without other nodes further in the chain being used. |
| Distance Scale | Scale the amount of distance from the source which the effect will be applied to. |
| Distance Offset | Offsets the distance field values, causing the generated distance field to expand of contract. |
| Procedural Root | The root node of the procedural network to calculate a distance from. | Procedural Root |
