Exposable Array
Exposable Array
Generates an Array passed through from a media server.
This node allows you to take full control over the arrays directly from the media server when running back as a block. This is useful for when you are trying to design the interactive setup where the media server is the main hub of control for the hardware that is connected to it. When exposed, the media server is able to push an array into the node/block.
JavaScript #
You can also programmatically address the Exposable Array using JavaScript with the following functions: SetTransformArrayPRS(), GetTransformArrayPRS(), SetTransformArrayColour(), GetTransformArrayColour(), SetTransformArrayUVScaleOffset() and GetTransformArrayUVScaleOffset().
Num Transforms Max number of elements for this node to track.
Transform Mode How the transform data is interpreted by Notch.
  • Position : Rotation Eulers, Scale,
  • Matrix 4x4 : 16 values in a 4x4 matrix
  • Position : Rotation Quaternion, Scale
Transform Data You must expose this value for the media server to be able to control the exposable array.
Apply Node Transform To Array Elements Only When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used.
