NDI Output
NDI Output
Broadcast a video feed via NDI.
This node sends the video or scene render it is attached to out via NDI. Multiple NDI outputs may be sent simultaneously from a single Notch layer. You can find more details in the NDI Protocol Section.
NDI signal will only be sent when the play head is playing.
Active Control whether the NDI stream is being sent.
NDI Sender Name The NDI stream name
