Iterative Cloner
Updated: 8 Jan 2026
Generates clones with an iterative transform change.
Updated: 8 Jan 2026
This node generates Clones by iteratively applying a transform to each new clone, such that the new clone offsets from the previous. This can create spirally and fractal like effects, where clones appear to grow out from a central point.
| Position X | Offsets the X position of each clone from the previous clone. |
| Position Y | Offsets the Y position of all clones from the previous clone. |
| Position Z | Offsets the Z position of all clones from the previous clone. |
| Rotation Heading | Offsets the rotation heading of all clones from the previous clone. |
| Rotation Pitch | Offsets the rotation pitch of all clones from the previous clone. |
| Rotation Bank | Offsets the rotation bank of all clones from the previous clone. |
| Scale X | Offsets the X scale of all clones from the previous clone. |
| Scale Y | Offsets the Y scale of all clones from the previous clone. |
| Scale Z | Offsets the Z scale of all clones from the previous clone. |
| Node Spawn Mode |
Change the order in which the cloned objects are assigned to clone instances.
| Random Seed | The seed for the node’s random number generators. Change it to produce a different variation without altering the parameters. |
| Num Clones | Number of copies of the input object created by the node. |
| First Clone | Chooses which clone is the first clone generated. |
| Clone Scale | Scale the size of all the clones uniformally. |
| Rotation Affects Positions | The rotation of the child object affects the position of the clones. |
| Scale Affects Positions | The scale of the child object affects the position of the clones. |
| Rotation Affects Clone Rotation | The rotation of the clones increases with each clone added. |
| Scale Affects Clone Scale | The scale of the new clone increases with each clone added. |
| Ease Clones In/Out | Enable easing so new clones don’t immediately appear. |
| UV Scale X Delta | Relative change to the uv scale along the x of the clone’s material, per clone. |
| UV Scale Y Delta | Relative change to the uv scale along the y of the clone’s material, per clone. |
| UV Offset X Delta | Relative change to the uv offset along the x axis of the clone’s material, per clone. |
| UV Offset Y Delta | Relative change to the uv offset along the y axis of the clone’s material, per clone. |
| Crop Left Delta | Relative change to the crop on the left of the clone’s uvs, per clone. |
| Crop Right Delta | Relative change to the crop on the right of the clone’s uvs, per clone. |
| Crop Top Delta | Relative change to the crop on the top of the clone’s uvs, per clone. |
| Crop Bottom Delta | Relative change to the crop on the bottom of the clone’s uvs, per clone. |
| Per Clone Position X | Changes the X position of each clone individually. |
| Per Clone Position Y | Changes the Y position of each clone individually. |
| Per Clone Position Z | Changes the Z position of each clone individually. |
| Per Clone Rotation Heading | Changes the heading rotation of each clone individually. |
| Per Clone Rotation Pitch | Changes the pitch rotation of each clone individually. |
| Per Clone Rotation Bank | Changes the bank rotation of each clone individually. |
| Per Clone Scale X | Changes the X scale of each clone individually. |
| Per Clone Scale Y | Changes the Y scale of each clone individually. |
| Per Clone Scale Z | Changes the Z scale of each clone individually. |
| Reset Per Clone Transform | . |
| Effectors | Control how the clones behave once spawned. See Effectors. | Plain Effector |
