Turbulence Deformer
Deform a mesh using a turbulence functionUpdated: 15 Sep 2026
Deform a mesh using a turbulence functionThis node deforms a mesh based on a turbulence function to create noisy displacements and random shapes.
| Weightmap | Add a weight map to determine where the deformer is more or less effective. |
| Apply Mode |
Choose whether the deformer applies to the individual vertices or the mesh chunks.
| Transform Space |
Choose which transform space the deformer uses for deformation. Does not affect falloffs.
| Blend Amount | Global override for how much the deformer affects the mesh. |
| Noise Scale | Scale the size of the generated fractal noise. |
| Lacunarity | How large the gaps between larger areas of noise are. |
| Gain | The overall smoothness of the generated fractal noise. |
| Num Octaves | How many time the noise generation is iterated. |
| Max Displacement | Limit the amount of displacement. |
| Animation Speed | Speed the deformer is animated at. |
| Time Mode |
How the deformer updates with relation to the timecode.
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Mask Image | Use an image to mask out areas for the deformer to not function. | Video Loader |
| Generated Weightmap | Add a weightmap to vary the strength of the deformer across the surface. | Generate Weightmap |
