Range Remap
Limit and remap the incoming modifier value.
This node limits the range of values that can be output and linearly remaps incoming values to fit within the output ranges.
For other methods to remap a value non-linearly, you can use the Expression Modifier
| Value | Base value to modify the output value with. |
| Modifier Operation |
These properties control the incoming data range. Values outside this range will be clamped.
| In Lower | Lowest value in that will be remapped into range. |
| In Upper | Highest value in that will be remapped into range. |
These properties control the outgoing data range.
| Out Lower | Lowest value that can be output. |
| Out Upper | Highest value that can be output. |
