Colour Correction
Colour Correction
Adjust the overall colour balance and ranges in an image.
This node modifies the current colour correction of an image. Useful for balancing out the colours from an image, matching the colours from different video sources, or creating new effects by exaggerating or diminishing the colours.
Apply To Filled Pixels Only Only apply the correction to pixels with content, leaving fully transparent areas untouched.
Clamp Source Colour Clamp the incoming colours to be between 0-1.
These properties balance the overal colour values in the image.
In Black Darken the dark parts of the image.
In White Brighten the light parts of the image.
Out Black Darkens the dark parts of the image.
Out White Brighten the light parts of the image.
Gamma Changes the gamma value of the image.
Brightness Control the brightness of the image.
Contrast Control the contrast of the image.
Saturation Control the saturation of the image.
Hue Control the hue of the image.
Tint the overall colours of the image.
Red Change the amount of red used in the whole image.
Green Change the amount of green used in the whole image.
Blue Change the amount of blue used in the whole image.
Red Power Curve Adjust the shape of the curve that controls the relationship between highlights, midtones and shadows for the red channel.
Green Power Curve Adjust the shape of the curve that controls the relationship between highlights, midtones and shadows for the green channel.
Blue Power Curve Adjust the shape of the curve that controls the relationship between highlights, midtones and shadows for the blue channel.
Tint the oveerall colours in the bright areas of the image.
Tint the oveerall colours in the middle value areas of the image.
Red Mid Change the amount of red used in the midtones of the image.
Green Mid Change the amount of green used in the midtones of the image.
Blue Mid Change the amount of blue used in the midtones of the image.
Tint the oveerall colours in the dark areas of the image.
Red Low Change the amount of red used in the dark parts of the image.
Green Low Change the amount of green used in the dark parts of the image.
Blue Low Change the amount of blue used in the dark parts of the image.
Red Hi The red channel gain applied to the brightest parts of the image.
Green Hi The green channel gain applied to the brightest parts of the image.
Blue Hi The blue channel gain applied to the brightest parts of the image.
