Multiplex Sources
Multiplex Sources
Takes multiple video inputs and outputs a single video based on the Source Index attribute.
This node takes multiple video inputs and outputs a single video based on the Source Index attribute. All connected video nodes are treated as active, even if they are not currently being used.
Source Index Select the source video to use from the input source.
SourcesAdd sources to select from.Video Loader
