Level Set (Field)
Updated: 6 Mar 2026
This node allows a Field to be used as a procedural generator source.
Updated: 6 Mar 2026
This node allows a Field System to be used as a procedural generator source. This path is useful for generating fluid like meshes via the Procedural Meshing Node.
| CSG Mode |
These options change how a this procedural node combines with the existing of the procedural system.
| CSG Blend Weight | How much the new procedural blends with the old procedurals, depending on the CSG Blend Weight. |
| Material Colour | Modify the colour for the procedural material. |
| Custom CSG Code | Type your Custom code here, using the HLSL language. Read more on Editable Code. |
| Affect Colour | Toggles whether colour is used or not. |
| Field Source | Connect a Field Level Set root to generate the procedural shape. | Field Level Set Root |
