Film Grading
Film Grading
Updated: 5 Jun 2026
Add a film grading effect to the image.
This node combines a few different effects together to create an easy filmic look. Useful for quickly adding a vignette, or adding some basic chromatic aberration to an image.
Blur Amount Amount of Blur to apply to the image.
Blur Scale Scale of the Blur effect.
Chromatic Amount Amount of chromatic aberration in the effect.
Vignette Width Control the size of the vignette
Tone Map Gamma Control the brightness of the effect
Noise Amount Amount of noise in the image
Centre X Change the x axis centre point along from which the chromatic aberration is drawn.
Centre Y Change the y axis centre point along from which the chromatic aberration is drawn.
Normalise Blur Steps Normalises the blur steps, so that they remain more accurate when at larger extremes.
Toggle which of the RGBA channels are affected by the effect.
