Colour Limiter
Updated: 20 Feb 2025
Limit the colour range to between two colours in the image.
This node limits the colour palette of the incoming image to between two selected colours, where the individual RGBA values can get no lower value than those of the Min Colour and no higher than the Max Colour.
| Min Colour | Choose the minimum colour value of the parent image is. |
| Max Colour | Choose the maximum colour value of the parent image is. |
