Using Notch in Hippotizer
Updated: 20 Nov 2025
Green Hippo have native Notch playback support from version 4.2 (patch required)
Features supported #
  • Pass textures/video from Hippo to Notch (e.g. SDI capture)
  • Pass textures/video out of Notch into Hippo (the resulting output)
  • Control parameters exposed in the Notch project
To preview or play content in Hippotizer you will need either :
  • Watermarked license (either separate or bundled in Builder Learning)
  • Full Playback license
Hippotizer ships with a set of 10 in-built Notch effects which work with all Hippotizer+ products out of the box. If you wish to playback Notch content outside of these Hippotizer in-built effects (i.e. custom blocks or Notch created blocks), you will require a full Notch Playback License.
Instructions #
Hippo Manual - Notch Integration
