Text String
Text String
Updated: 20 Jan 2026
Editable Text String.
This node can be used to represent a text string, which can be used to input text into other nodes - typically the Text node or string manipulation nodes such as Merge Text and Split Text.
Text Text string to be used as a source in another node.
