Text Case
Text Case
Updated: 20 Jan 2026
Change the case of a Text String.
This node converts all the characters in the string into either lower-case or upper-case, for use within a Text node or to be processed by other text string nodes.
Text The text string to change to lowercase.
Text Case The mode used to transform the input string.
  • Lowercase : The string is converted to lowercase.
  • Uppercase : The string is converted to uppercase.
Text StringOverwrite the text string attribute with an input text string.Text String
