Split Text
Split Text
Updated: 20 Jan 2026
Split a text strings from a seperator.
This node splits text strings into an array, then using the index parameter one can be used as an input into other nodes - typically the Text node or to be processed by other text string nodes.
Text Overwrite the text string attribute with an input text string.
Separator The character used to split text up by.
Output Split The index in the new array of text to output from.
Text StringsOverwrite the text string attribute with an input text string.Text String
