Spline
Spline
Updated: 30 Jan 2026
Generates a 3D Spline for Procedurals
This node generates a distance field from an input Spline. The input spline can be modified via their control points, and the procedural spline will dynamically update to match.
A mesh can be used as input if it has the Object To Lines deformer. The Duplicate Spline deformer can also be used to easily draw multiple splines.
Thickness The thickness of the generate spline.
Spline Time Min The start point of the SDF along the length of the spline, by a value normalised by the splines length.
Spline Time Max The end point of the SDF along the length of the spline, by a value normalised by the splines length.
Spline Time Offset Offset the SDF by a value normalised by the splines length. When used with the Spline Time Min and Spline Time Max, can deform the mesh along the spline.
Generate Colours Takes the colours from the original Spline and passes them into the SDF colour channel. Has no affect when Affect Colour is disabled.
Generate UVs Generate texture coordinates in the SDF, for use with Materials. Can reduce performance slightly.
SplineThe spline to use to generate the procedural.Spline
