Reaction-Diffusion
Reaction-Diffusion
Updated: 30 Jan 2026
Performs reaction-diffusion simulation to a Procedural system.
Performs reaction-diffusion simulation, using a procedural input to restrict the placement of seeds and another procedural input to restrict growth.
This node simulates the Gray-Scott reaction-diffusion process, which can be thought of as a kind of fluid simulation with an extra step that creates organic-like patterns which grow out from seed points. Seed points are created by random spread, and if a seed restrictor is used then seeds outside of the restrictor volume are rejected. The growth is limited by the growth restrictor volume.
More information on the general topic of reaction-diffusion simulation can be found here.
Filled Mode Thickness of the Shell wall, when Filled Mode is set to Shell.
Shell Thickness Thickness of the Shell wall, when Filled Mode is set to Shell.
Simulation Grid Width The voxel width resolution of the simulation grid used for performing the reaction-diffusion simulation
Simulation Grid Height The voxel height resolution of the simulation grid used for performing the reaction-diffusion simulation
Simulation Grid Depth The voxel depth resolution of the simulation grid used for performing the reaction-diffusion simulation
Initialisation Seed The randomisation of the seed points can be changed by changing this seed value
Smoothen When enabled, the surface extracted from the simulation is smoothened internally
Growth Pattern Changes the type of growth that occurs. at 0.0 the growth will be more like a web, and at 1.0 the growth will be more like separated blobs.
Growth Rate Controls the speed at which the growth progresses.
Invert Growth Restriction Inverts the inside/outside sense of the restriction volume.
Invert Seed Restriction Inverts the inside/outside sense of the seed volume.
Seed Density Increase this property to make the seed points appear more densely packed together. decrease it to spread them out more.
Growth RestrictorRestrict the growth rate.3D Primitive
Bounds OverrideOverride the bounds.Bounding Box
Seed RestrictorRestrict where seed values can be positioned.3D Primitive
