Editable Code
Editable Code
Updated: 6 Mar 2026
Generates a shape for a procedural system from custom code.
This node allows a custom piece of HLSL code to be written to produce a distance value from which a procedural shape will be created. For best results with this node you should have a working knowledge of the HLSL shading language, and signed distance fields.
IMPORTANT: The custom code is inserted into a larger HLSL function, and therefore creating functions is not supported.
Example #
localPos.y += param2 * sin( 1.0 * localPos.x + param1 * 2.4 ) * param0;
localPos.x += param2 * sin( 1.0 * localPos.z + param1 * 2.4 ) * param0;
sdfValue = length(max(abs(localPos) - 1.0, 0.0 ));
Code Type your code here
Param 0 Variable that can be used in the code
Param 1 Variable that can be used in the code
Param 2 Variable that can be used in the code
Always Enabled When enabled, this node will run regardless of time bar enable/disable. Due to how Notch handles shader generation with procedurals, with this enabled the node runs more efficiently.
