Cellular Noise
Cellular Noise
Updated: 30 Jan 2026
Generates a cellular noise pattern for a procedural.
This node generates an infinite cellular noise pattern. It works by dividing the space in to cells and placing a point in each cell, which is expanded to a sphere. the points are then randomly offset to form the cellular noise.
Cell Size Size of the generated cells.
Jitter How much the spheres are randomly moved from their original cell positions.
Transform ControllerSet the origin/center point of the noise.Null
