Pyroclastic Displacement
Updated: 30 Jan 2026
Add blobby noise to a procedural.
Applies a noise-based deformation to a procedural. The noise generated forms a dense fusion of blobs.
Num Octaves How many octaves of noise are generated.
Noise Scale Size of the noise generated.
Amplitude How greatly the generated noise displaces the distance field.
Blob Size Controls the overall ‘blobiness’ of the displacement.
Animation Rate When not zero, this property will control how fast the noise animates.
Colour 0 If the renderer of the procedural generates colours, then this colour will be used for the deformed shape.
Colour 1 If the renderer of the procedural generates colours, then this colour will be used for the deformed shape.
