Melt
Melt
Updated: 30 Jan 2026
Smooth a procedural.
This node smooths the shape a procedural in 3D space, much like how a blur smooths an image in 2D space.
Fill Mode Thickness of the Shell wall, when Filled Mode is set to Shell.
Shell Thickness Thickness of the Shell wall, when Filled Mode is set to Shell.
Grid Width Size of the SDF Grid used for generating this effect.
Grid Height Size of the SDF Grid used for generating this effect.
Grid Depth Size of the SDF Grid used for generating this effect.
Iterations How many iterations of the melft function are run.
Error Tolerance Expands the allowable values for generating the Distance Field. Higher values often get rid of jagged edges and odd rendering behaviours, but with decreased performance.
Use Colour Affect the colour of the generated procedural system. only functions with ‘Generate Colours’ enabled in some Procedural Render nodes.
