FBM Displacement
FBM Displacement
Updated: 30 Jan 2026
Apply FBM deformation to a procedural.
This node applies an FBM (Fractal Brownian Motion) deformation to the procedural. Useful for adding noise to a surface or cloud.
Amplitude How greatly the generated noise adds to the distance field.
Colour 0 If the renderer in the procedural network produces colour then this colour will be used for the displaced shape.
Colour 1 If the renderer in the procedural network produces colour then this colour will be used for the displaced shape.
Apply Mode How the displacement will be applied to the distance field.
  • Add : Add to the current distance field.
  • Subtract : Subtract from the distance field.
  • Add Signed : Only add to the distance field when the fbm displacement is positive.
