Sine Warp
Sine Warp
Updated: 19 Feb 2025
Warps an image with a ripple emanating from the centre of the screen.
This node warps an image with a ripple emanating from the centre of the screen.
Sine Major Scale Axis Change the peak value for the major axis of the sine wave.
Sine Minor Scale Axis Change the peak value for the minor axis of the sine wave.
Noise Amount How much is applied to the warp.
Falloff Range The range at which the effect works.
Max Displacement Maximum amount the image can be displaced.
Animation Rate Change the rate at which the sine wave is animated.
