Bump Map Warp
Bump Map Warp
Updated: 19 Feb 2025
Warps an image based off of a bump map.
This node warps an image based off of a bump map. The warp is generated by creating a copy of the image with a slight offset and multiplied. If there is no input connected to the Image Node input then the scene render is used as a source bump map.
Falloff Range How far the falloff for the warp reaches.
Displacement Amount X How much the images are displaced along the x axis.
Displacement Amount Y How much the images are displaced along the y axis.
Bias Displacement Direction (Grey = 0) Change the displacement direction so that a middle grey value has no displacement, and values darker or brighter will push the displacement in opposite directions.
Normalise Displacement Direction Force the displacement direction to apply evenly in each direction. this does not include alpha modulation.
Modulate Displacement Amount By Alpha Control the strength of the displacement based on the input images alpha channel
Control how much the RGBA channels displace the X and Y axes individually.
Image NodeThe source bump map for the warp.Video Loader
