Output GBuffer
Output GBuffer
Updated: 24 Mar 2025
Render a layers GBuffers directly.
This node allows you to render one of the various GBuffers to the screen. GBuffers are geometry buffers - rendered images that contain geometric information rendered from the objects in the current view, such as normals, material IDs, positions etc. These may be useful when rendered and loaded into other software. This node can be connected to a Render Layer, Render to Texture, or the Root node - other nodes will output nothing.
Some channels will not work with the standard renderer. (Metalicness,Roughness…)
Composite Colour
node-output-gbuffer
Colour
node-output-gbuffer
Alpha
node-output-gbuffer
Depth Camera Space
node-output-gbuffer
Metalicness
node-output-gbuffer
Rougnhess
node-output-gbuffer
Specular Colour
node-output-gbuffer
Normal Camera Space
node-output-gbuffer
World position
node-output-gbuffer
Material ID
node-output-gbuffer
Object ID
node-output-gbuffer
Normal World Space
node-output-gbuffer
Channel Select which gbuffer channel to output.
  • Normal - World Place : Surfaces are coloured based on a normal map generated in world space.
  • Normal - Camera Space : Surfaces are coloured based on a normal map generated in camera space.
  • Colour : Surfaces are only coloured based on their colour values.
  • Specular Colour : Surfaces are only coloured by their specular colours.
  • Metalicness : Surfaces are only coloured by their metalicness colours.
  • Roughness : Surfaces are only coloured by their roughness colours.
  • Depth - Camera Space : Surfaces are coloured based on their distance from the camera.
  • World Position : Objects are coloured based on their position in the scene in world space.
  • Object Mask : Objects in the scene are combined in screen space and a mask is output.
  • Object ID : Objects are colour based on their object id.
  • Material ID : Objects are colour based on their materials.
  • Object ID (Fake Colours) : Objects are colour based on their object id, and a random colour is used.
  • Material ID (Fake Colours) : Objects are colour based on their materials, and a random colour is used.
Apply To Solid Geometry Only Only apply the effect to solid geometry. Allows other objects in the scene to still be visible and un affected.
Render LayerSelect a specific render layer to output the GBuffer for.Render Layer
