Frame Difference
Frame Difference
Updated: 20 Feb 2025
Subtract the current frame of a video from the previous frames.
This node takes the incoming frame and subtracts it against the previous image, highlighting the areas where the frame has changed. Useful for detecting changes in a video, or for highlighting areas of motion in a scene.
Intensity Scale The intensity of the effect that is applied.
Num Frames Number of frames other than the original frame included in the difference calculation.
Use Absolute Difference Toggles whether magnitudes of differences between pixels should be used, or whether differences only occur when the new pixel is brighter than the old.
