Frame Delay
Frame Delay
Updated: 20 Feb 2026
Add a Delay to a video.
This node delays the image played by a specified frame amount. It is also used as a generalised buffer for the Frame Delay Frame node, which picks specific frames from the buffer.
Num Delay Frame Number of frames the image will be delayed by. Max 2500.
Buffer Format Select which format the buffered frames are kept in.
  • RGBA : The rgba values are all saved.
  • Greyscale : The image is saved in greyscale.
  • DXT1 Compressed RGB : The image is compressed using the dxt1 format - ignores alpha values.
