Edge Detect
Edge Detect
Updated: 20 Feb 2025
Detect the edges in an image.
This node evaluates an image to try and identify details and edges within. Useful for creating neon effects from a simple video image with a Glow node, or for highlighting edges of an image when in additive mode.
Mode Change which edge detection method is used.
  • Simple : Compares pixel intensity differences with neighbours.
  • Sobel : Uses a convolution kernel. Suppresses more noise compared to the Simple mode.
  • Canny : Most accurate and has the least noise, but slowest.
Colour Edit the colour of the edge
Threshold Change the threshold for the edge detection.
Scale Scale the brightness for the effect.
Width Change the width of the output lines detected.
Pixel Width When sobel mode is chosen pixel width defines the width of the edge.
