Colour Reduce
Colour Reduce
Updated: 3 Dec 2025
Set the amount of distinct colour in the image.
This node allows you to set the amount of distinct colours in the image by either quantizing the colours of the source image, or using the colour ramp input to define the amount of colours, as well as what colours they are.
Colour Selection Mode Where to select the colours from to reduce the image down to.
  • Current Frame : Set the colours per frame based on the current frame.
  • First Frame : Set the colours based on the first frame.
  • Adapt : Set the colours per frame based on the current frame, but set an adaption rate to slow down the transition between colours.
  • Colour Ramp : Use the colour ramp input to set the colours.
Adaption Rate Set the rate of change between colour sets when using “Adapt” mode.
Max Colours Set the maximum amount of colours to quantize the image to. Has no effect if “Colour Ramp” mode is used.
Colour RampColours to use when “Colour Selection Mode” is set to “Colour Ramp”.Colour Ramp
Effect Amount ImageSet the amount of effect that the node has based on an image.Polygon
