Colour Curves
Colour Curves
Updated: 28 Jan 2026
Remaps colour values using curves.
This node provides precise control over an image’s brightness, contrast, and colour by remapping input tonal values using editable colour curves. The master RGB curve can adjust overall shadows, midtones, and highlights while preserving colour balance, while the individual red, green, and blue curves allow for precise, per-channel colour correction and creative colour shifts.
In each curve, the horizontal axis represents input values and the vertical axis represents output values. By default, the curve is a straight diagonal line from bottom left to top right, meaning input values are mapped directly to output values with no change. By editing the curve you can affect the relationship between input and output values at any point along the curve.
Editing The Curve #
  • Double LMB in the curve editor to add a point.
  • Double LMB on an existing point to delete it.
Apply To Filled Pixel Only Only apply to pixels with some content on them. useful for virtual production contexts, where post-fx applied to the front plate shouldn’t apply over the backplate.
RGB Control the red, green and blue colour channels simultaneously.
RGB Curve Boost or reduce the values of the red, green and blue values simultaneously along a curve.
Red Control the red colour channel individually.
Red Curve Boost or reduce the values of the red channel along a curve.
Green Control the green colour channel individually.
Green Curve Boost or reduce the values of the green channel along a curve.
Blue Control the blue colour channel individually.
Blue Curve Boost or reduce the values of the blue channel along a curve.
