Post-FX
iconPost-FX
Updated: 20 Jan 2026
Post-FX nodes are mostly effects added onto an image, after the scene is rendered. These can vary from Colour Correction to FXAA Antialiasing, and are generally used to enhance an image. The order of operations are decided based on the Y value of the node in the nodegraph, or the X values if the Y values are the same. Nodes with larger X or Y values will be calculated first. Unlike the Video Processing Nodes (many of which are shared with these nodes), these nodes only affect the parent, and do not contain a copy of the image.
Post-FX can be applied directly to these nodes, however if applied to other nodes it will affect the whole scene, not just the parent node.
Post-FX have been separated into 9 groups:
Antialiasing
These nodes calculate better antialiasing than the default.
FXAA AntialiasingFXAA Antialiasing
Remove aliasing in an image using Fast Approximate Anti-Aliasing.
Blur
Blur nodes defocus images, making them appears less clear.
BlurBlur
Add a simple blur effect to an image.
Directional BlurDirectional Blur
Add a blur effect along a direction to an image.
Edge-Aware BlurEdge-Aware Blur
Add a blur effect but preserve detailed areas to an image.
Feedback BlurFeedback Blur
Add a blur which trails from a line across the image.
FFT Blur / GlowFFT Blur / Glow
Add a wider blur or glow effect to an image.
Frame FeedbackFrame Feedback
Overlay the previous frame over the current frame.
Gaussian BlurGaussian Blur
An efficient, resolution-independent blur with variable intensity.
GlowGlow
Add a simple glow effect to an image.
Glow 2Glow 2
Add a glow effect which stays resolution independent to an image.
Physical GlowPhysical Glow
Add a physical glow effect to an image.
Radial BlurRadial Blur
Add a blur effect which pushes outwards from an origin point.
Tilt ShiftTilt Shift
Add a tilt shift effect to an image.
VHS BlurVHS Blur
Add a damaged VHS effect to an image.
Colour
These nodes allow for the adjusting of RGBA colour channels.
Apply Colour LUTApply Colour LUT
Apply a Colour Look Up Table (LUT) to an image.
Colour Channel MixerColour Channel Mixer
Mix the colour and alpha channels of an image.
Colour CorrectionColour Correction
Adjust the overall colour balance and ranges in an image.
Colour CurvesColour Curves
Remaps colour values using curves.
Colour GradingColour Grading
Adjust the overall distribution of colour in the image.
Colour LimiterColour Limiter
Limit the colour range to between two colours in the image.
Colour ReduceColour Reduce
Set the amount of distinct colour in the image.
Combine Colour GradesCombine Colour Grades
Combine multiple Colour Grading nodes together.
InvertInvert
Invert the colours in an image.
Local ContrastLocal Contrast
Increase the small scale contrast of an image.
RecolourRecolour
Recolour an image based on an input image or gradient.
StrobeStrobe
Add a flashing strobe to the image.
TintTint
Add an overall tint to the image.
Tone MapTone Map
Apply a tone mapping process to an image.
TritoneTritone
Colour the source using highlights, midtones and shadows.
Distortion
Changes the shape of the image in different ways.
DistortionDistortion
Add digital distortion to the image.
DitherDither
Add a dithering effect to the image.
Line DistortionLine Distortion
Add growing lines to an image.
NoiseNoise
Add random noise to the image.
RGB DistortionRGB Distortion
Add RGB sine distortion to an image.
Generators
These nodes effect the input image by compositing mathematically generated patterns onto them.
Composite ImageComposite Image
Composite an image directly in a Post-FX chain.
Gradient 2DGradient 2D
Generate a 2D gradient to input into other nodes.
Gradient 3DGradient 3D
Generate a 3D gradient that appears on all objects in the scene.
Gradient PatchGradient Patch
Generate a simple colour pattern.
GridGrid
Generate a 3D grid that appears on all objects in the scene.
Voronoi 2DVoronoi 2D
Generate a mesh based on a particle system.
Image Compression
Compress or decompress images with different kinds of compression.
Compress UV AnimationCompress UV Animation
Compress a UV animation for export.
Decompress UV AnimationDecompress UV Animation
Decompresses a compressed UV animation.
Image Processing
These nodes analyse and modify the image with different effects.
Auto Key Colour MaskAuto Key Colour Mask
Automatically generate a mask for an image.
Background Plate SubtractBackground Plate Subtract
Removes the background from a video using a background plate.
Bit CrushBit Crush
Reduce the colour resolution in an image.
Capture Image FileCapture Image File
Save a still image within a Post-FX chain.
Channel BooleanChannel Boolean
Swap the RGBA colour channels.
Chroma KeyChroma Key
Generate a mask for an image using Chroma Keying.
CropCrop
Add a crop to an image.
Custom Shader Post EffectCustom Shader Post Effect
Add a custom .fx shader script as a Post-FX
DilateDilate
Expand bright pixels and shrink darker pixels.
Edge DetectEdge Detect
Detect the edges in an image.
ErodeErode
Shrink bright pixels and expand darker pixels.
Frame BufferFrame Buffer
Hold a frame of video for a period of time.
Frame DelayFrame Delay
Add a Delay to a video.
Frame DifferenceFrame Difference
Subtract the current frame of a video from the previous frames.
Frame LoopFrame Loop
Dynamically Loop a number of frames.
Generate Normal MapGenerate Normal Map
Generate a normal map from an image.
Histogram NormaliseHistogram Normalise
Use a histogram to normalise the colours.
Histogram ThresholdHistogram Threshold
A thresholding process based on the percentage of pixels rather than their intensity.
Key Colour MaskKey Colour Mask
Generate a mask for an image using a specified colour.
Kuwahara FilterKuwahara Filter
This node performs a Kuwahara filter kernel operation on the input image, which can result in a painting-like effect.
Median FilterMedian Filter
Add a noise reducing filter to the image.
NDI OutputNDI Output
Broadcast a video feed via NDI.
NVIDIA Virtual BackgroundNVIDIA Virtual Background
Generate a mask for an image using NVIDIA RTX to mask out human forms.
Output GBufferOutput GBuffer
Render a layers GBuffers directly.
Range RemapRange Remap
Remap the overall colours of an image.
Replace ColourReplace Colour
Replace a colour with a different colour.
ThresholdThreshold
Limit the colour in an image.
Video ExporterVideo Exporter
Export a video within a Post-FX chain.
Stylisation
These nodes modify the image with various stylised effects.
Block GlitchBlock Glitch
Add an animated block glitch.
Chroma GlitchChroma Glitch
Add an animated colour glitch.
Cross HatchCross Hatch
Add a cross hatch effect to an image.
Dot MatrixDot Matrix
Add a dot matrix effect to an image.
Film GradingFilm Grading
Add a film grading effect to the image.
HalftoneHalftone
Add a half-tone effect to an image.
Image DistanceImage Distance
Generates a distance field from an image and applies a colour gradient to it
Motion DatamoshMotion Datamosh
Add a datamosh effect to the image.
OutlinesOutlines
Add outlines to geometry in the scene.
Physical Lens FlarePhysical Lens Flare
Add a physically correct lens flare reflections and a starburst flare to the scene.
Pixel SortPixel Sort
Add a simple pixels sorting algorithm to the image.
PixelatePixelate
This node pixelates an image, giving it a lower resolution.
SharpenSharpen
Add a sharpen effect to the image.
Slit ScanSlit Scan
Add a slit-scan effect to an image.
StreaksStreaks
This node applies a streak effect to the image.
Vector BlurVector Blur
Add a gradient based blur to an image.
VHS ScanlinesVHS Scanlines
Add a VHS scanline effect to an image.
Voronoi Post ProcessVoronoi Post Process
Add a Voronoi breakup effect to an image.
Warping
These nodes take an image and stretch or squash them in different ways.
Barrel DistortionBarrel Distortion
Simulate distortion of real-world camera lenses in an image.
Bezier WarpBezier Warp
Warps using a bezier control grid and 8 control points.
Bump Map WarpBump Map Warp
Warps an image based off of a bump map.
Curl Noise WarpCurl Noise Warp
Warps using a curl noise function.
Droste WarpDroste Warp
Applies a Droste function, creating an infinitely warping warp.
Field Position-Based WarpField Position-Based Warp
Warps an image based on the movement vectors of an input field.
Field WarpField Warp
Warps an image based off of a field system.
Four Point WarpFour Point Warp
Warps from 4 cornered sections of the image.
MirrorMirror
Mirrors one side of the image onto the other side.
Moebius WarpMoebius Warp
Applies a Moebius function, creating an infinitely warping warp.
Polar WarpPolar Warp
Warp the image using polar coordinates.
Radial WarpRadial Warp
This node warps the screen radially around the center point.
Randomise TilesRandomise Tiles
Randomise parts of the image based on an input image.
RippleRipple
Warps an image a ripple emanating from the center of the screen.
Screen WarpScreen Warp
Adds a bulge effect to the image.
Sine WarpSine Warp
Warps an image with a ripple emanating from the centre of the screen.
StretchStretch
Stretches a cross section of the image.
Transform ImageTransform Image
Apply a transform to the image.
Turbulence WarpTurbulence Warp
Warps an image with a turbulence.
Twirl Image WarpTwirl Image Warp
Warps the image in a twist around the center.
Water RipplesWater Ripples
Simulate water on an image.
Nodes
Post-FX NullPost-FX Null
Allows stacks of Post-FX nodes to be connected as its children.
