Rigid Body Procedural
Allows a procedural system to be used for collisions with rigid bodies.
The Rigid Body Procedural node allows a procedural system to be used as a collider for rigid bodies. It must be parented to a Rigid Body Root. This node is great for getting complicated physics interactions at high frame rates.
Procedural RootThe root node of a procedural system to use as a collision surface.Procedural Root
