Rigid Body
Rigid Body
Updated: 6 Oct 2025
Generates a static or dynamic rigid body collision object.
The Rigid Body node defines a static or dynamic rigid body collision object. This is a 3D body that moves under physics and collides with other objects in the same physics system - under the same Physics Root. It must be parented to a Physics Root for physics to work. Useful for quickly setting up collision surfaces, such as side barriers or angled ground planes.
  • Static : A static rigid body does not move and can’t be moved by physics, but will act as a collider for other dynamic objects. An example could be a floor or wall.
  • Kinematic : A kinematic rigid body is not moved by physics but has a velocity that can affect dynamic bodies. An example could be a moving platform or rotating collider.
  • Dynamic After Collision : A dynamic rigid body has its initial position set by its transform, but transform control is taken over by physics as soon as the object collides.
  • Disabled : Physics will not be applied, and the object will be ignored for simulation.
  • Baked : All the rigid body’s transforms will be controlled by the baked physics data.
GPU Transform Only If selected, the transform of the body is maintained on GPU only. This reduces latency and increases performance but means that parenting to the object, e.g. using it to transform lights will not work.
  • Sphere : A sphere, useful for emulating balls or roundish objects.
  • Box : A box, useful for emulating boxy objects.
  • Plane : A flat infinite plane, useful for setting up solid walls. May only be static or kinematic.
  • 3D Object (Convex Hull) : A convex hull derived from the geometry of the node, with its own modes to set the convex hull generation below.
  • 3D Object (Use Original Geometry) : The original triangle geometry of the node, if applicable. Best used with low poly meshes.
  • 14 Faces (Capsule) - X-Axis : A simplified capsule with 10 sides pointing along the X axis.
  • 14 Faces (Capsule) - Y-Axis : A simplified capsule with 10 sides pointing along the Y axis.
  • 14 Faces (Capsule) - Z-Axis : A simplified capsule with 10 sides pointing along the Z axis.
Show Rigid Body Displays a debug view of the actual rigid body shapes being used to calculate collisions.
Bake Physics Transforms Bake the physics transforms so they are no longer simulated per frame, and simply animated back.
Baked Transform The baked transforms, useful for adjusting the animation after baking.
Object NodeAllows a 3D Object node to be connected to define the shape of the body.3D Object
