Mesh Attribute Weight
Updated: 15 Jan 2026
Generates weight values using attributes sampled from a mesh, at the closest point on the mesh to the particle.
This node generates a per-particle weight values using attributes sampled from a mesh. These can then be used to vary the strength of affectors on the parent particle system.
The output from this node are particle weights which are unique to the parent particle system, so can’t be used to influence other particle systems.
Input Channel Choose which attribute to use to generate the weight.
  • Distance From Surface : Generates the weight based on the particles distance from the surface of the mesh.
  • UV X : Generates the weight based on the X value of the object’s UV coordinates.
  • UV Y : Generates the weight based on the Y value of the object’s UV coordinates.
  • Weightmap Value : Generates the weight based on a generated weightmap applied to the input object.
Use Absolute Value (Ignore Sign) If value is negative, make it positive.
Attribute Scale Scale the value of the selected attribute.
Attribute Bias Offset the value of the selected attribute.
Invert Value Invert the value of the selected attribute.
Radius Radius of influence when using “Distance From Surface”.
ObjectObject to generate attribute weight from.3D Object
WeightmapWeightmap to use to generate particle weights when using “Weightmap Value”.Generate Weightmap
