Soft Ball Renderer
Soft Ball Renderer
Updated: 13 Jan 2026
Renders particles as soft body spheres.
This node uses an approximated soft body simulation to render particle as soft spheres. The spheres can interact with each other softly, like spherical soft bodies, and also be constrained by collisions using particle collision affectors such as the Primitive Collision Affector.
This node generates geometry for each particle and can accumulate lots of geometry very fast when using a lot of particles. To reduce the amount of geometry generated, either lower the “Num Particles” in the Particle Root node, and / or reduce the amount of "Subdivisions" in the Soft Ball Renderer node.
Max Radius Maximum size of the ball.
Radius Randomness How much randomness in the size of the ball.
Spring Dampening How much to dampen the springiness effect applied to the particles.
Smooth Iterations How much smoothing to apply to the geometry of the balls.
Use Particle Colours If enabled then the colour of each ball will be taken from it’s particle.
Subdivisions How much to subdivide the geometry of the balls.
Max Generated Vertices Readout of how many vertices will be generated if all particles are spawned.
Num Particles Used Readout of the maximum amount of particles in the root.
MaterialAdd a material to override the internal default material.Material
