Point Renderer
Point Renderer
Updated: 14 Jan 2026
Renders a each particle as a sprite.
This node renders a point sprite for every particle. A point sprite is a plain rectangle which is positioned in 3D space, is rotated to face the camera and may be textured. This is the most commonly used rendering node for particle effects. An image or video may be used as a source for the sprite, set via the Texture parameter, or via a Video Node connected to the Image Node input. If an alpha channel is available, The alpha channel of the image is used to affect particle transparency.
Particles, like other 3D objects, are rendered to normalised viewport coordinates with sub-pixel accuracy. For some forms of output target such as low resolution LED screens it may be desirable to make particles fit exactly to pixels. The Pixel-Align Output control can be used to snap them to pixel boundaries and the size limits may optionally be specified in pixels.
Texture Select a texture to be rendered at each particles position.
Particle Alpha Control the alpha value for each particle.
Blend Mode Edit the blend mode used for the particles. See Blend Modes for details.
Particle Size Edit the size of the particles once they are rendered.
Particle X Scale Control the x-scale of the sprites emitted.
Particle Y Scale Control the y-scale of the sprites emitted.
Pixel-Align Output Align the rendered points exactly to screen pixels, with no sub-pixel interpolation.
Particle Scale Coeffs How much the particle scales are affected by the node at different stages of the particle life. Values 1 and 2 are control points, and are used to control the curve between values 0 and 3.
Screen Size Limits The minimum and maximum size of the rendered particle in normalised screen coordiates.
Specify Size Limits In Pixels Indicates whether particle size limits are specified in normalised viewport coordinates which are consistent across different render resolutions, or in pixels.
Size Randomness Control the randomness in size of the particles.
Scale Over Time Change the scale of the sprites over time.
Scale Over Time Mode How the particle is scaled over time.
  • Particle Time : Individual particles scale over their life time; particles that live longer will end up scaling more.
  • Normalised Emitter Time : Individual particles scale over the time of the emitter.
  • Normalised Particle Time : Individual particles scale over their life time; the time is normalised so all particles reach the same scale at death.
Scale / Alpha Mode Control how the scale and alpha modes relate to each other.
Size curve Control the curve of how particle scale over their life.
Rotation Control the rotation of the sprites.
Rotation Randomness Control how much randomness is in the rotation of the particles.
Rotation Follows Direction Toggle whether the rotation of the particles follows the direction the particle is moving in.
Alignment Control what the orientation of the sprites aligns too once spawned.
Render Geometry Type Choose whether the particles spawn as single pixel points or spawn as a sprite texture.
Ray Tracing Is ray tracing used.
Blur Mip Levels The number of MIP levels in the image that may be used for blurring effects.
Use Soft Depth Clipping Fade particles out when at the edge of the camera clip range rather than a hard clip.
Improved Sort Accuracy Used to improve sort accuracy.
Motion Blur Amount Control the amount of motion blur.
Mipmap Enabled Toggle whether mipmaps are enabled.
Depth Of Field Amount How much depth of field effects the particles.
Randomise DOF Amount Randomises the position of particles based on their distance from the focus plane.
Depth Of Field Texture Size The size of the texture used when depth of field is enabled.
These properties control spritesheet animation for input images which contain an animated texture.
Use Texture Animation Edit whether the texture animation is shown with the rendering.
Texture Animation Rate Edit whether the texture animation is shown with the rendering.
Texture Animation Loop Frame The index of the frame that will be jumped to after a loop.
Texture Animation End Frame The index of the last frame in the texture, which causes a loop when reached.
Num Frames X Change how many tiles the sprite image will be spread across the x axis.
Num Frames Y Change how many tiles the sprite image will be spread across the y axis.
Texture Start Frame Mode The method by which the start frame of the texture animation is chosen.
  • Frame 0 : The animation always starts at frame 0 for every particle.
  • Random : A random frame is chosen as the start frame.
  • Particle Index : The particle’s emission sequence index is used to choose the start frame.
  • Emitter Index : The particle’s emitter is used to choose the start frame, so all particles from one emitter start on the same frame.
Choose Frame By Best Fit To Colour Choose the texture animation frame by analysing which frame best fits the colour of the particle.
These properties control how the renderer is lit by other particles.
Lit Control whether the particles are lit.
Volumetric Shadows Enable volumetric shadows.
Volumetric Shadows Alpha The transparency of the volumetric shadows.
Cast Shadows Cast shadows from particles onto the scene.
Shadow Particle Size The size of the particles when rendered into the shadow map.
Shadow Particle Alpha The transparency of the particles when rendered into the shadow map.
Local Lighting Enabled Toggles per-pixel lighting on particles.
Curvature The curvature of the particle when used for lighting.
Image NodeUsed to provide a texture for sprite rendering.Video Node
LightsControl which light nodes affect the particle shading.Light
