Particles To Point Geometry
Updated: 14 Jan 2026
Renders particles as raytraced spheres.
This node renders a raytraced sphere for all particles. Although it is not geometry like a primitive, the sphere will correctly simulate lighting and material shading the same way as a 3D object, and a Material node can be added for greater control.
For a particle system that only needs small points or spheres, this node can be faster and higher quality. for a wide variety of shapes, use the Particle Cloner node.
Emissive Materials can be connected, but will not emit lighting. If needed, look at a Particle Cloner workflow instead.
Point Size Edit the size of the particles once they are rendered.
Point Size Randomness Control the randomness in size of the particles.
Luminance Control the luminance of the rendered particles.
MaterialAdd a material to override the internal default material.Material
