Line Connection Renderer
Updated: 14 Jan 2026
Renders lines between nearby particles.
This node renders lines between pairs of nearby particles, giving the impression of a mesh-like structure. The connection pairs are determined by locating particles that are near to each other using a spatial grid. This grid may be scaled by connecting a node to the Bounding Box input, changing the spawning behaviour and potentially affecting performance. Once connected, particles remain joined by a line for a period of time unless one of the particles dies.
Geometry Type How the lines are generated.
  • Thin Transparent Lines : Draws set width thin lines.
  • Thick Transparent Lines : Draws thick lines that can be controlled by the “Line Thickness” property.
  • Line Geometry : Generates lines ars geometry. Can be used with materials.
Particle Alpha Change the alpha value for the particles.
Distance Threshold Maximum distance a line can be drawn at.
Min Distance Threshold Maximum distance a line can be drawn at.
Line Thickness Edit the thickness of the line rendered. Only functions if “Use Thick Lines” is enabled.
Depth Of Field Amount How much depth of field effects the particles.
Line Connection Lifetime Length of time a line between two points can exist.
Affected Radius The radius of the area of space within which connections may be generated.
Max X Difference The maximum separation of particles in the X axis that can be connected.
Max Y Difference The maximum separation of particles in the Y axis that can be connected.
Max Z Difference The maximum separation of particles in the Z axis that can be connected.
Cast Shadows Control whether shadows are cast.
Blend Mode Edit the blend mode used for the particles. See Blend Modes for details.
Use Thick Lines Toggle whether the lines have 3D thickness, or not.
Max Lines Per Particle Maximum number of lines that can be drawn from each particle.
Use Locality Grid TBC.
Affected Centre PositionControls the centre position of a radial area of space where the connections may be generated.Null
