Procedural Emitter
Procedural Emitter
Updated: 11 Nov 2025
Emit particles from a Procedural system.
This node is used to emit particles from a Procedural system, using the Signed Distance Field to indicate where to emit the particles and modulate their alpha.
Life Control the randomness for the life of each particle.
These properties control how the procedural system is sourced for particle emission.
Distance To Alpha Scale Scale the alpha of the particles based on distance from the procedural surface.
Use Procedural Distance As Scale Activate using procedural distance as the particle scale.
Distance To Scale Scale the size of the particles based on distance from the procedural surface.
Min Distance Minimum distance away from the surface to spawn particles, facing inwards. Particles closer to the surface than this value will not be spawned.
Max Distance Maximum distance away from the surface to spawn particles, facing inwards. Particles further away from to the surface than this value will not be spawned.
Cull Overlapping Particles Remove particles which are too spawned close to each other.
Cull Overlapping Particles Scale Scale the radius used to select which particles should be removed.
Min Scale The minimum scale of the particles, if the Distance To Scale is not 0.
Max Scale The maximum scale fo the particles, if the Distance To Scale is not 0
Use Procedural Colours Allow the particles to pick up colours from the procedural system.
Grid Size The number of voxels on one axis used to spawn the particles. High resolutions will result in a denser generation of particles, relative to the size of the bounding box.
Procedural RootConnect a source procedural node.Procedural Root
Bounding BoxLimits the area that the procedural emitter will use.Bounding Box
