Primitive Emitter
Primitive Emitter
Updated: 11 Nov 2025
Emit particles from a primitive shape.
This node emits particles in the form of a 3D primitive shape. The Emitter Type parameter defines which shape is used. Particles can be emitted on the surface of the shape or inside the volume of the shape, depending on the Emit On Surface parameter.
If the emitter has an animated transform, emitted particles may track the motion of the primitive so they appear to stick to or follow the moving primitive. The Parent Transform Weight parameter scales this effect.
Emitter Type The shape in which the particles are emitted.
  • Sphere : Particles spawn within a 3D sphere.
  • Box : Particles spawn within a 3D Cube.
  • Cylinder : Particles spawn within a Cylinder.
  • Plane : Particles spawn on a flat, 2D Plane.
  • 2D Grid : Particles spawn along the edges of a 2D grid.
  • 3D Grid : Particles spawn along the edges of a 3D grid.
  • Point : all particles spawn at the same point in 3D space.
  • Circle : Particles spawn along the edge of a circle.
Repeating Random Toggle whether the random number generation repeats, and particles are emitted with repeated transform properties.
Seed Choose a seed for the random number generation.
Uniform Distribution Make sure the particle generation is evenly distributed throughout the object.
Emit On Surface Toggle whether particles emit on the surface of the emitter object.
Normal Direction Controls the way particle normals are generated.
  • Emitter Shape : use the underlying primitive shape.
  • Emitter Motion : normals point in the direction of motion of the emitter.
  • Emitter Facing : normals point in the facing direction of the emitter.
Emission Velocity How much of the motion from the emitter is transferred to the generated particles. Because this is an initial velocity, further transforms by the emitter will not be inherited.
Parent Transform Weight How much the transform of the parent affects the transform of the particles.
Parent Transform Weight Randomness Adds some randomness to the transform weight per particle, meaning some particles will follow the parent transforms less.
Parent Transform Weight Life Coeffs How much the particles are affected by the parent nodes transforms at different stages of the particles life cycle. Values 2 and 3 are control points, and are used to control the curve between values
Emission Interval Set the update interval of the emission.
  • Step : Only update the emission calculations once per frame.
  • Continuous : Update the emission calculations continuously between frames. Helps alleviate gaps in emission.
Limit Seed Position Count Limits the amount of random position seed values that are possible.
Limit Seed Position Count Sets the max allowed random position seed values that are possible.
Fade Falloff Coefficient Change the weighting of the fade falloff to either speed up or slow down over time.
