Mesh Emitter
Mesh Emitter
Updated: 11 Nov 2025
Emit particles from a mesh.
This node emits particles from a 3D mesh. The mesh must be connected via the “Object Nodes” input, and can be a 3D Object node, a Shape 3D node, a Text node or a Depth Camera / Kinect Mesh. If no suitable node is connected then no emission will occur. Deforming and animating objects are supported. The node chooses locations on the mesh to emit from in one of several ways depending on the Spawn Mode attribute. The vertices of the mesh can be used directly, or random points spread evenly across the polygon surface or the edges of the mesh can be used.
The mesh emitter can only be used by one material at a time, if you have more than one material you will need to bake the textures together.
Spawn Mode Control how the particles spawn, either on vertices or on polygons.
  • Vertices : Spawn only from vertices.
  • Polygons : Spawn on the surface of the mesh’s polygons.
  • Edges : Spawn on the edges of the mesh.
  • Vertices - Follow Edges : Spawn from vertices and them follow the edges. Add some Emission Velocity to see the movement.
Incidence Angle Emission Coeffs The angle at which particles are emitted from the 3d object.
Parent Transform Weight How much the transform of the parent affects the transform of the particles.
Parent Transform Weight Life Coeffs How much the particles are affected by the parent nodes transforms at different stages of the particles life cycle. Values 2 and 3 are control points, and are used to control the curve between values
Parent Transform Randomness Controls the randomness of the parent transform weight.
Emission Velocity How much of the motion from the source mesh is transferred to the generated particles. Spawn Mode must be Polygons.
Emission Velocity Randomness How much randomness to add the the emission velocity.
Emission Normal Direction Velocity Speed at which particles after emission, along the angle of the normal. Spawn Mode must be Polygons.
Seed Select a seed for the random number generation.
Use Vertex Colours Toggle whether particles inherit the vertex colour of the mesh.
Use Mesh Colours Toggle whether particles are given colours based on the colour of the mesh.
Distribution Weightmap Index Select the weightmap to use for distribution by index.
Bake Texture Colours Toggle whether textures on the materials of the mesh should be applied to particle colours.
Edge Follow - Stop Age Controls how many edges a particle will follow before it stops moving.
Max Particles Per Vertex When using the Spawn Mode of Vertices or Vertices Follow Edges, this attribute sets the max number of particles emitted from a vertex that can be in flight at any time
Randomise Order Toggle whether particle generation should be done randomly, or in an ordered list through the mesh.
Polys To Emit From Amount Controls how many of the polygons on the mesh will emit particles.
Emit Distance From Surface Distance from the surface that the particles emit from.
Emitter Sort Key Controls the processing order of the emitter.
Pixel Cull Mode What channel to use to cull the particles.
Alpha threshold Threshold of the alpha when using alpha as the “Pixel Cull Mode”.
Object NodesParticles will be emitted from the connected mesh.3D Object
WeightmapDefine the the strength of emission using a weightmap.Generate Weightmap
