Velocity Affector
Velocity Affector
Updated: 15 Dec 2025
Applies a constant velocity to particles.
This node applies a constant velocity to the affected particles. This is typically used to make particles move in a regular, linear fashion, e.g. wind effects or repulsions.
Inner Radius Alter the inner radius up to which the affector is fully effective.
Mode Choose what kind of velocity affects the particles.
Falloff Shape The primitive shape used to calculate the falloff weight for the affector.
  • Point : Uses the distance from the centre position of the node
  • Line : Uses the distance from an infinite line in the x axis centred at the position of the node
  • Plane : Uses the distance from an infinite plane in the xy axis centred at the position of the node.
Velocity NodeA transform node that overrides the velocity direction and source position.Null
