Scale Affector
Scale Affector
Updated: 15 Dec 2025
Apply changes to the scale of particles.
This node changes the scale of particles as they enter its falloff region.
Mode Mode in which to set the scale of the particles.
  • Linear : .
  • Random : Randomly assigns scales based on the min/max scale settings.
  • Turbulence : Assign scale values based on turbulence noise.
  • Sine : Assign scale values based on a sine function.
  • Triangle : Assign scale values based on a triangle function.
Scale Amount How much to scale all particles by.
Scale Min Minimum scale of the particles.
Scale Max Maximum scale of the particles.
Inner Radius Alter the inner radius up to which the affector is fully effective.
Blend Amount How much affect the affector has on the particle system.
Blend Mode How the changes to the Scale Amount will affect the particles.
  • Blend : Multiplies the Scale Amount and the current particle scale.
  • Add : The Scale Amount will be added to the current value.
  • Subtract : The Scale Amount will be subtracted from the current value.
  • Max : The larger value between the Scale Amount and the current particle size is chosen.
  • Min : The smaller value between the Scale Amount and the current particle size is chosen.
Falloff Shape Select which shape to calculate the falloff from.
