Procedural Affector
Procedural Affector
Updated: 15 Dec 2025
Allows particles to interact with procedurals.
This node simulates collisions between particles and Procedural meshing object. Different effects can be achieved, such as attraction and repulsion from object surfaces or making particles flow around the particle surface, as selected by the Mode parameter.
At least one Procedural Object Node must be connected via the Procedural Nodes input for this node to be effective.
Mode Choose how the node interacts with the input object.
  • Attractor : Moves the particles towards the mesh.
  • Repel : Moves the particles away from the mesh.
  • Collision : Particles collide with the object and bounce off.
  • Follow Contours : Particles flow around the surface of the object.
Radius Limit the radius at which particles can be affected by the affector.
Colour Weight Controls how much the colour value generated by the affector is blended with the particle’s current colour.
Is Inside Threshold Distance inside or outside the object at which collisions are considered to have occured.
Surface Distance Target The radius of the particle when determining collisions.
On Surface Velocity Scale Scales the velocity of the particle when it is on the surface of the object.
Collision Event Likeliness Controls for what fraction of collisions a collision event should be triggered.
Use Colours Toggle whether to use the colours input by the mesh.
Invert Space Invert the object so areas inside the mesh are considered hollow and areas outside are filled.
Procedural NodeThe source Procedural mesh for the particles to be affected by.Procedural Meshing
