Force Affector
Force Affector
Updated: 15 Dec 2025
Applies a force to particles.
This node applies a force to the affected particles. This is typically used to give particles a constant acceleration to simulate e.g. gravity.
Amount How strong an effect the force has on the particles.
Mode Change which kind of force is applied.
  • Directional Force : The force is applied in a particular direction, along the z axis.
  • Repel : The particles move away from the node.
  • Attract : The particles move towards the node.
Transform NodesApply the transforms of other nodes to this node.Null
Force TransformerTransforms the force direction.Null
