Fluid SPH Affector
Fluid SPH Affector
Updated: 15 Dec 2025
Simulates fluid dynamics on Particles with an SPH simulation.
This node simulates fluid dynamics on a particle system using the SPH (Smoothed Particle Hydrodynamics) simulation method. This is typically used to simulate liquid effects. It solves a fluid simulation by locally solving pressure forces between a particle and others nearby. This allows particles to affect each other and to move in a locally coherent manner. SPH works well for liquid effects like water.
The solver takes into account both the position and velocity of particles and their neighbours. The Viscosity attribute is used to make the simulation behave as a thicker liquid. Surface Tension is used to keep particles together like droplets of water. The radius around each particle in which they interact with their neighbours is controlled using the Cell Size attribute. Larger cell sizes may result in a smoother simulation that increases performance demands. The simulation may be switched from 3D to 2D, in which case one axis is dropped from the simulation.
The grid resolution and size used for the pressure solver is key to the detail and performance of the resultant simulation. A higher resolution grid over a smaller area will give a more detailed simulation, but higher resolution grids are slower to process.
Weight How strong an effect has on the particles.
Cell Size The area around each particle that resists other particles from getting within a certain distance.
Smoothing Kernel Defines how each particle’s influence is distributed over space
Viscosity The viscosity of the fluid, where smaller values make it more gas-like and larger values make it thicker - more like treacle.
Gravity How strong gravity is on the particles.
Pressure Scale Scales the amount by which particles push apart from each other.
Rest Density Controls the base density of the fluid.
Surface Tension How much the particles want to stay together at their surface.
Max Force The limit on the force applied to the particles as a result of the simulation.
Dampening The amount particle forces are damped - so they decay over time, rather than moving constantly.
Area Scale Scales the area of space the simulation is processing.
Mode Choose how the fluid simulation is calculated.
  • SPH : Use smoothed-particle hydrodynamics to generate the fluid dynamics.
  • Position Based : Uses position based fluids, faster but less realistic.
  • Inter-Particle Force : Simply pushes particles away from their neighbours.
Dimension Choose whether the effect is 2d or 3d.
Grid Resolution The resolution of the underlying grid used in neighbourhood searches.
Grid Transform NodesControl the transform of the underlying grid used in neighbourhood searches.Null
